1 - 3 of 3 Posts
Need help as to what's wrong with the fan. Fan works every now and then. You go to work one day and your fan/air condition is working. After stopping for gas, the fan just don't work. The A/C unit however still works. Tried moving the fuse a couple times and it comes back on(the fan). This has been doing it for the last few days- intermittent use of it and finally got no use of the fan lately. My impression is that there can be a possible connection problem or loose wire. Do you think it needs a new blower/fan? My camry is a 96 4 cylinder with auto trans. Any help will be appreciated. Thanks.
You mean the fans on your radiator ? Check all electrical connections going to both fans and give them a good spray of wd40, This could help...
1 - 3 of 3 Posts
