Hi Audio Experts. Need a bit of help. I'm a bit of a home audio guy on a budget but not quite as into car audio. I don't want to spend 10 hours or $500 customizing my car.
2002 Avalon - Factory JBL 5 Way system. Reconed the Sub a while back and it worked great. Noticed I had a "pop" in the left rear speaker. Sounds great, then will occasionally pop. Wanted to upgrade the speakers anyway (figured this was not a speaker issue) so I just put in a decent set of Kickers using the factory enclosures. Of course, the pop is still there and getting worse.
Not sure if the issue is caused by the Amp (under the passenger seat I think) or in the radio. I don't mind upgrading the radio to something more modern/better. Does anyone have a suggestion on what is causing the issue, how I can check it and what I should consider replacing?
No way am I paying $500 to replace the factory Amp. I've been told I can replace the radio and bypass the amp but i would think it would sound weak as I understand a new radio alone would not be able to power the sub. I'm sure I'll have a question to any reply but I would really appreciate any help from you audiophiles out there. Thanks!
