Okay, I really need a little assitance on this one. The shop where my car resides is trying to finish up the swap. They noticed that this engine has an external coil ignition system as opposed to the internal one on my old 3sfe. The coil on this engine however is missing. Is it possible to use my old 3sfe stuff and convert it to an internal system or do I need to go steal the parts off the USDM 3sfe that was in the rav 4 which should also have the external coil(which I am not even 100% sure that it does). Does anyone know about this for sure? Do I need a new ECU to make this function correctly. I just figured my old 3sfe ECU should work fine.
Also, is there a different mount on these late model 3sfe's? It seems like we may have to fab a left side engine mount. Is this right? I thought it mounted just like the original 3sfe.
