The timing belt broke on my wifes 01 solara 2.2L Auto (5S-FE Engine) and I have been following the write up by Trioxide1
http://www.toyotanation.com/forum/1...ment-w-pictures.html#/topics/428257?_k=ngefea
on how to change the timing belt and I have replaced the oil pump oring and seal, water pump crankshaft seal and camshaft seal. I still need to install the tensioner, idler pulley and the belt. but before I do all of that how do I determine if the engine is at #1TDC compression vs exhaust and how do I set the camshaft to be in time to the crankshaft. I know about the timing marks but am unsure how to determine tdc and how to ensure the camshaft is set correctly.
If anyone knows of a write or is willing to walk me thru it I would greatly appreciate it.
Thanks
Travis
Thanks
Travis
