Hi guys, bit of a problem I can't figure out...hopefully someone has seen this.
Both my rear windows on my gen 5 mysteriously stopped operating, at the same time. They are very rarely used and I have a hard time believeing the switches or the motors are the problem. The front two windows work OK.
The rear windows don't operate up or down using either the master switch panel on the driver door or the switches at the rear doors themselves.
I checked all the fuses under the dash, they test OK.
Through a search on the forums, someone identified a faulty fuse causing all the windows as well as the sunroof to stop working. This fuse was the big 30amp kind labelled "PWR 1". Seeing as my other windows work except the rears, I figure I have a different problem.
Has anyone else had this happen or have some recommendations (is there a fuse I don't know about)?
Any insight would help :thumbsup:
