I recently just rebuild my 22r and finally got her running smoothly, or so I think.
The motor sounds good, starts right up and idles smooth. When I drove her around the neighborhood everything went well. It wasn't until I took her out on the main road I noticed something wrong.
She won't go above 40-45, doesn't matter what gear. I would give her all she's got in first and second throughout the neighborhood and hit max rpms just fine. Would pull beautifully.
I did however just but some used 4.10 gears in the rear and I am wondering if that could be the issue?
Speed should be irrelevant to the rear diff right? Just rpms and load? That's what I don't get. Engine is fine in neutral, rpms climb and lower just fine. Throughout 1st, 2nd and mostly 3rd everything is great but at 40 ish mph it feels like I'm pulling a boat uphill. Also there where zero issues with the transmission prior to rebuild of motor.
Thanks for any adive, much appreciated.
