1 - 3 of 3 Posts
I own a 2007 xrunner and recently had the motor replace because of knocking issues. The shop I took it to put in a 2011 1grfe I believe from a sr5. Now I have issues p0011 and p0012. The motor it self is good. Compression, sensors, etc. how do I fix this problem?
2008 Sienna LE
Based on a Google search, P0011 (timing over-advanced) and P0012 (timing over-retarded) are codes for the variable valve timing. Both are Bank 1, so the right (passenger side) cylinder head. Possibly a bad camshaft position sensor. The engine is out of a different year truck, so was the ECU swapped as well? It may be as easy as a reflash of the ECU (by the dealer), or it might take some parts.
The truck the engine came out of might have been throwing P0011/P0112 codes before it ended up in the junkyard. I would go back to the shop that did the swap.
2008 Sienna LE
Also, do you have information on the truck that the donor engine came out of, like what the odometer reading was? If it was a really high mileage engine, it could also have a bad timing chain (lots of slack) or a bad tensioner.
1 - 3 of 3 Posts
