1 - 3 of 3 Posts
Need parts numbers for the vacuum switching valves :
for the EGR system
for the Evap Canister (should be two, I think)
Trying to figure out the numbers at Rock Auto site is confusing, they're called different things by different manufacturers vs the Toyota Repair Manual.
My car: 2001 Camry 4 cylinder, 'late' emissions system
Discussion Starter · #3 ·
To update :
I had two codes p0401 and p0440 which are egr insufficient flow, and evap emissions (small leak, iirc).
Looked at the egr vacuum modulator, and egr valve - both looked clean and clear. Decided to change out the vsv for the egr. Did the trick apparently, 0401 code hasn't returned at ~60 miles later.
New gas cap last year, so I decided to change the canister vsv, and the vsv for the canister mounted at the air cleaner. 0440 code has not yet returned.
Annual inspection passed.
The parts I ordered -
911606 (911-606) vsv Dorman
911604 (911-604) vsv Dorman
2M1257 airtex wells vap canister vent valve/solenoid
(Actually, the valve in the Airtex box was a Denso labeled unit - don't know if they just got mixed up or what, but I'm not complaining.)
1 - 3 of 3 Posts
