Pull the shifter surround. It pops right out. Gently pull up on it from the front, then the rear. After that you have two screws to remove from the radio surround. Be careful, this is an often broken and thus difficult to replace piece.
After you remove those two pieces you will see that the radio/pocket/cupholder assembly is held in by four more screws/bolts. Once you take those out the whole kit and kaboodle pops right out and unplugs.
