1 - 9 of 9 Posts
money pit
i found a set of rims for cheap just have the specs and im not to knowledgable on rims, anybody know if these will fit an o6 tacoma 4x4? 17x9. offset 18, bolt pattern 6x5.55
A.K.A. Ty
2005 Tacoma TRD OR
I think these wheels actually have a higher backspacing than the stock wheels, which means they won't fit. Are you sure the offset is 18 and not -18? It makes a world of difference. With 18mm offset, I don't think they'll fit, but I think they will with -18mm. We'd really need NorCal or another wheel guru to reply to verify my assumption.
money pit
NorCalTacoma said:
What brand and model are the wheels?
Can you provide a link?
Do you plan to lift and use larger tires?
From the looks of it, you can use these wheels if you plan to use a 265/70-17 tire.
i was waitin to see if norcal would chime in, they are helo maxx and he said 18 backspacing but i looked and for that size on our trucks helo says it should be -18 so im sure they are. yea im lifting it and i was lookin to get the 265's. thanks for feedback
07 Silver Taco
i have the helomaxx6 in black 17x9 295/70/17 some trim work needs to be done but looks great. wish u the best
1 - 9 of 9 Posts
