Do you have the Dist. adv. as far as you can go in the CCW direction. if so you may be off by one tooth on the Dist. also have you checked to see what codes you are getting?
I have tried the distributor several different ways...and no matter what i do i cant get the timing close to 5 degrees...It runs at what looks like at least 20 because the mark only goes to 12 and its way past that...I am getting codes 4,11,12...Is the jumper for the codes the same as one as for the timing? Because when I jumper it the engine light starts to blink but the idle doesnt change at all which I have read is supposed toDo you have the Dist. adv. as far as you can go in the CCW direction. if so you may be off by one tooth on the Dist. also have you checked to see what codes you are getting?
