Need stock amp help
822 1
I just got a new Blaupunkt deck and was wondering what would be the difference between hooking it up with the stock and and without the stcok amp?
1 - 2 of 2 Posts
Highlander
You could use the OEM/stock amp to feed off the preamp output from the Blaupunkt deck. But the OEM amp was designed with the OEM deck in mind, so level matching will not be properly set. I've tried this before, and I'd stick with the Blaupunkt's built-in amp instead, and bypass the OEM.
1 - 2 of 2 Posts
