Need your guidance on 1999 Camry power window motor or regulator diagnosis?
Thanks for your input to my earlier threads.
1) My 1999 Camry power window acts weirdly. I am able to bring down the window quickly, but I find difficult to bring it up.
2) The other window came down, but did not go up. As I pressed the switch, I hear motor rotating sound. :frown:
It moves little by little. It moves little. If I press the PW button , it will not respond. I need to wait for awhile to move up little. The mechanic suggest to change the PW motor and another mechanic suggest to change PW regulator + motor together.
I did review some old threads on this subject, where they suggest to look into door boot for cracked wires. There were some links to photos/videos, but those were broken.
Is there a way to test with multimeter for voltage/continuity to isolate the issues (broken wire, bad switch, bad motor etc)?
I did check the flow in connector comes to window switch after removing the connector from switch. I find 1st two pins shows 12V, but other pins shows 0 .
Thanks for sharing. :nerd:
