Needing Some Help! Strange noise while turning.
1034 Views 4 Replies 4 Participants Last post by  nvrsmr08
I have a 2008 toyota trd double cab tacoma... my issues is that when I turn the steering wheel to make a cut ont he road and release the wheel to come back to the normal position to go straight... i heart a popping noise... it sounds like plastic, but i can't pen point where it is coming from... does anyone else have this issue?
1 - 5 of 5 Posts
are you lifted?
No i am not lifted... just stock
Are all of you're fender plastics tight, and where they should be? I'm wondering if maybe you lost a clip or something and a piece of fender plastic is hanging lower than it should, and is getting caught on tire tread, and snapping back once the tire is turned back.
Yeah I had the same kind of situation. I took it to the dealer and there was a loose bolt in my steering column not a problem since.
1 - 5 of 5 Posts
