We just got this 1991 Camry DX. it's a 4 cyl. & it only has 75k miles on it. It has a few kinks in it, the alignment's off & sometimes as you accelerate, it stutters, the distributor cap is new, i'm not sure what the problem is, any ideas? Well, it's still not bad for $700 & i have the '88 Camry Wagon which has a lot of problems, so wost comes to worst, i can pull parts from there. i took some pix of it...so here it is...
damn. thats clean. ur problem im guessing distributor? mine is having the similar problem and its my distributor. considering normal tune up, check ur timing.
Well...we've solved the stuttering problem for the most part. We initially thought it was the starter & the distributor cap, but it turned out to be the spark plugs. The gap was too big so it was getting the proper spark sometimes, so we fixed the gap & now, it starts fine & the hesitation is mostly gone. Now, we just gotta get alignment & rebuilt the distributor cap & it'll b perfect. I have to take out the clock out of the '88 b/c the clock in the '91 doesn't work. I checked the fuses & the fuse for the clock, cigarette lighter & some other stuff so i checked the cigarette lighter & it works so then that means the clock is out. Any1 have any suggestions on how I would get around the steering column? I'm gonna take apart the '88 1st & then I'll go to the other one once I can figure out how to get around the steering column...any ideas on how to get around it, I'm open for suggestions.
As long as you have a DX/LE (tilt steering colum), it is a simple job. 5 screws hold the gauge cluster surround in place, 4 hold the gauge cluster itself in place and then you can pop the clock out.
