cool A newb that has actually done his homework !! First off you have an SR5 which will make things a bit more difficult when you modify since it isnt the GT-S..... But! sounds like you plan on replacing alot of things anyways so it really doesnt matter...
Exhaust- sounds good! A good header that you should also consider is the OBX header By far one of the best mods i did to my car ! Really Deepened the exhaust note!
Suspension- You are correct Apex & Eibach are very good springs but many have said that the eibachs dont have enough drop.. but thats not what eibach designed them for anyways... they give alot better handling & a "slight" drop but not enough to loose all that wheel gap ; )
Swaybars tighten up your body roll when you turn right or left.... Strut bars are the fancy bars under the hood that connect to the left & right strut mounts...
Exterior - side skirts will add alot to the SR5 !! i would love to see you do this.... when u install them make dam sure they are sealed up well !!! you dont want water getting in an rusting out everything like you will see on most GT-S's when you remove the skirts...
Sidemarkers are personal preffrance i guess
Mudflaps ! ive removed mine & will never go back !
Engine ideas another personal prefferance i think... some will vouch for 1 or the other... i did the 4agze since i track my car & DD my car Its a great motor with factory reliability..& the SC sounds sweet ; )
