Here's my latest mini-mod.
I've been looking for an easy/cheap solution for an engine bay light. I liked the idea of LED strips under the hood but didn't care for the cost or zip-tying. Also, I wanted to be able to move light around in case I needed it in a specific location...here's what I came up with.
1.I purchased this Electro-Tek 12v 10w magnetic-mount light with 10 foot retractable power cord at KMart for $3. I actually bought 2. I might add the other later.
2. Cut off the cigarette lighter adapter. Unscrewed unit and painted it black with Plasti-dip rattle can paint.
3. Dremeled dummy switch to install lighted mini switch (Pepboys)
4. Added an add-a-circuit ($7 Autozone) to the 10amp washer fuse and added a 3amp fuse for the light. Wired to power terminal on switch. Only hot fuse without ignition is the 20amp turn signal fuse (too big for add-a-circuit :thumbdown).
5. Grounded switch behind kick panel.
6. Split ground (black) and power wires (black with white stripe) of light and run power wire to accessory terminal of switch.
All basic wiring but thought I'd write it out for those unfamiliar.
7. Ground black wire of light to threaded hole (8mm bolt). Need to add wire loom to *********** wire.
8. Magnet holds light behind the engine fuse box. Clears hood struts and never moves.
9. Flip dash switch and enjoy plenty of light wherever you want it. All 10' feet of it for only a few bucks. :naughty:
Photo with NO flash.
