Thanks much guys. Yeah waiting to tune until the bolt ons are hooked up makes sense. How low can you safely tune LIFT to kick in? I have heard some say they set it to 5k or so. And once you swap out that ecu how hard is it to program lift kick in? Also would that still smog here in CA?
I personally am a handling/response and agility buff so I have been focusing hardcore on tremendous response (both from engine and suspension) and also braking (slotted and cross drilled rotors etc.)
Regarding your question, every 2ZZ-GE car is a bit different. It is all where about where changing the cam switch over to the big cam without losing torque since the big cam requires a lot of air/gas mixture for high levels of combustion.
The most common range is 5200 - 5800 rpm. One Corolla XRS got its best engagement at 4800 rpm, but that was only one of a kind. No other XRS made power/torque with the big cam engaging so far down low.
Again, it is all determined during tuning of the ECU and as long as the torque curve is not dipping downwards, the tuner keeps lowering the lift engagement.
If you want to know more, you should contact redliner9k. He is the 2ZZ-GE tuning GURU and he has developed many parts for Corolla XRS himself (PPE Engineering race header, PFC harness for Corolla XRS).
He also owns a 200+ wheel HP N/A XRS with a 9000 rpm redline (250
[email protected] crank)
Here is his youtube channel:
http://www.youtube.com/user/Redliner9k
