Status
Not open for further replies.
1 - 2 of 2 Posts
Discussion Starter #2
What causes hybrid batteries to degrade and fail?
Eventually all batteries will fail. Hybrid Electric Vehicle (HEV) NiMh batteries have a life cycle. When the hybrid battery does not last as long as the rest of the vehicle, replacing it costs several thousand dollars and creates hazardous environmental waste. Delaying battery failure beyond the service life of the vehicle will reduce the negative environmental impact of hybrid vehicle ownership and save the vehicle owner thousands of dollars.
This graph depicts the typical life cycle of a Hybrid Electric Vehicle (HEV) hybrid battery:
There are three major phases of hybrid battery lifespan. Usable capacity and performance decreasing as the battery ages:
Typically begins: Typically ends: Phase 1: Healthy hybrid battery New Vehicle 3-6 years Phase 2: Weakened/weakening hybrid battery 3-6 years 5-11 years Phase 3: "Failed" hybrid battery (DTC code present) 5-11 years
Each hybrid battery 'pack' is comprised of many individual battery cells. Consumer hybrid electric vehicles have anywhere from 120 to 240 individual battery cells. Each cell is about the size of a typical D cell battery. At the beginning of the hybrid battery’s life, each cell easily provides all of the energy needed to propel the vehicle and to stay in sync with other cells in the battery pack. As time progresses, the battery will start to degrade and the cells will fall out of sync with each other. Results of this degradation include:
(1) usable cell capacity is reduced
(2) cells drift out of balance with each other (voltage delta).
The speed of this deterioration is determined by a variety of factors, including vehicle make/model, climate, driving habits, variation in battery cell construction, and more.
This battery deterioration means that the individual cells within the battery pack can have a different charge level and capacity - they are no longer 'in sync' with each other. Some cells can be 'full' while other cells in the same battery pack are 'empty'. The overall battery pack performance is limited by the vehicle's battery management system to the weakest cell when discharging and the strongest cell while charging. As a result, the wider the cell imbalance, the narrower the usable range of the hybrid battery becomes. The car's battery management system uses only a limited range of the battery cells actual physical capacity (80%-40% for Toyota and 80%-20% for Honda). As the usable capacity decreases and the cells become further and further out of balance with each other, the vehicle us able to use less and less of the batteries actual capacity. The vehicle cannot correct this imbalance problem on its own. The car cannot force the cells back into balance with each other.
If no attention is given to the hybrid battery, it will 'fail' and the check engine light/hybrid battery light will be illuminated.
How do I know if my hybrid battery is failing?
There are several subtle cues displayed by a hybrid vehicle that can alert you to degrading hybrid battery capacity & performance. If not acted upon, the battery will ultimately display a fault code for battery 'failure'. By paying attention to the warning signs and performing preventative care on the battery before it 'fails', you can easily improve battery health and prolong its life. Prolong Battery Systems will improve hybrid battery performance, save you thousands of dollars in avoided replacement hybrid battery costs, and benefit the environment by requiring one less hybrid battery to be manufactured. (Note: The symptoms described below are applicable to Toyota vehicles. Honda vehicles display similar symptoms. Feel free to give us a call and we can describe the Honda symptoms for you.)
The first indication of decreased battery performance is a reduction on fuel economy and diminished vehicle performance. The vehicle does not get the same fuel mileage that it used to and it feels sluggish - lacking in power during acceleration. If equipped, EV mode may be less frequent and for shorter duration then when the vehicle was newer. This happens because as the hybrid battery weakens, the vehicle is forced to use less of the battery and more of the gas engine. It also spends more time charging the hybrid battery in the background (i.e. not shown on the dash). Both of these behaviors reduce fuel economy. This can last for several months as the battery weakens and fuel economy/performance progressively decreases. Note: sometimes under inflated tires can cause similar symptoms. We recommend checking your tire pressure to be sure that is not the cause of decreased fuel economy.
The second warning that your hybrid battery is failing is called negative battery recalibrations. This is initially seen when parking the car for a few days (such as over a weekend) or when parking the vehicle overnight. Just before the vehicle is parked, the dash battery display shows a full or near full hybrid battery. When the car is started the next morning (or a few mornings later) the battery display shows an empty or near empty battery. The empty battery indication can be displayed immediately when the car is started or drop from full to empty in the first few minutes of operating the vehicle. This occurs most often in warmer climates or seasons, but as the battery degrades will happen in any climate. This is a clear sign of a weak battery that needs attention soon. If ignored, the battery will soon progress to the point of failure. If treated with Prolong Battery Systems before the battery degrades further, the success rate for recovering the pack and restoring it to good operating condition is nearly 100%.
The third and final warning the vehicle displays of a failing hybrid battery is negative recalibrations that occur while the vehicle is being operated. These recalibrations often occurs on warm days or when idling the vehicle for longer periods (such as waiting for a parking spot or railroad crossing), but as the battery weakens can happen at any time. These are seen as the dashboard battery charge display suddenly dropping from near full to near empty. This drop is followed by the gasoline engine revving to a higher than normal idle speed while force charging the battery from empty to full. This event is easily visible on the dashboard battery display and can be audibly heard by the loud, unusual high idling of the gasoline engine. This can be very unsettling behavior as the vehicle seems to ‘take over’ and ignore driver inputs while force re-charging the battery. This is a red flag, serious battery issues are imminent. In these cases, we strongly recommend using the Prolong Battery Reconditioning Package to perform a preventative battery reconditioning as soon as possible. Ignoring these symptoms for more than a few weeks will result in the battery displaying a failure code and being stranded on the side of the road. If treated with Prolong Battery Systems as soon as these symptoms become present, the success rate for recovering the pack and restoring it to good operating condition is nearly 90%.
The next phase of battery failure is a failure light on the dash and cell failure. Our products can still help vehicle owners in this situation, but the success rate depends on how long it has been since the failure first appeared. If this describes your car, please give us a call to discuss your specific situation and learn how much our products can help you and your hybrid vehicle battery.
https://hybridautomotive.com/pages/faq
1 - 2 of 2 Posts
Status
