Hello All-
First, thank you to all who contribute to this site! I've found it to be very useful when researching for modifications and best practices. I hope to contribute as I learn more about this car.
For about 3 years I have wanted a MKII Turbo. Alas other priorities have taken the MR2 out of limelight, but as of Sept 15, I have one to call my own. A 1991 MKII Turbo, Black T-Tops with 45K original miles and without a lot of modications. It appears to be very well cared for as evidenced by all fluids being fresh, interior is perfect, paint looks very good, and overall it runs very well. This one does not have power steering or leather, but it does have A/C, premium stereo, ABS, and foglights.
When I purchased it, the car was bone stock except for Lenso 17" rims/Dunlop tires, an Eclipse DVD/NAV CD system, and an ATS TD06 turno kit with Tial wastegate and downpipe (main cat removed). The turbo was replaced by the prior owner as a recommendation by the dealer, but in reality I think the stock CT26 was fine. The owner complained of hesitation...looks to me like the ground cables were shot and the rotor/cap was well past replacement time.
I've put about 3K on it this fall, but it is now "under construction" in the garage for the winter (too much salt here in Ohio). My other rides are an '05 4Runner, a Yamaha FJR1300 sport-touring motorcycle (capable of 155mph--1/4 mile in 11.02, yet still comfortable enough to ride for days on end) and a Yamaha dirt Bike ('05 YZF250).
I have several mods planned for the duece...nothing too extreme...mostly a little more performance and reliability.
First things first--the fluids looks fresh, but I'm going to change out everything. I've bled the brake system, but will also do the clutch fluid , MT oil, coolant, and engine oil. I've already Seafoamed the gas, intake, and oil (engine interior).
I already rebuilt the rear brakes (new rotors/pads/clips, Goodridge lines) as this was one item that was worn out (looks like the pads were not installed properly). It also needs a new antenna assembly as the internal gearing is stripped.
Mods to do this winter:
-Hyperground system (already completed, just need to install the battery to engine harness)
-Complete sound deadening (interior has been removed already)
-Polk db6500 component speakers in front
-ATS TB intake
-New plugs/rotor/wires/cap (already completed)
-New vaccum lines all around with T-bolt clamps
-7.5" Spal fan on intercooler
- Engine lid fan
-Intercooler piping heat shiedling
-Clean throttle body and MAF
-Check voltage/resistance of electrical components
-K&N FIPK
-TwoRus MBC
-Homemade FCD
-hardwired radar detector and cell phone charger
-XM radio
-Rust removal on underbody
-New radiator cap
-heatshield on wiring/cables
-New emergency brake cable (already completed)
-Clean up battery and connections (completed)
-Steam clean carpet
-Replace as many coolant hoses as I can get to
-Replace fuel filter
-Autometer Boost and voltage guages
-Keyless entry with turbo timer (maybe remote start??)
-TwoRus shifter kit
Probably a few other items I'm not mentioning.
I'm hoping by the end of March it will be roaring again. My username reflects the sound this car makes...the wastegate dump pipe is open, making a "WOOOLLLFFFF" sound (not to mention the larger turbo).
Anyway, glad to be part of the community! Thanks for reading this far and hope to contribute to the board.
Any comments as to other "must do" mods for reliability performance are appreciated!!! Im hoping to get around 230RWHPO and a much quieter cabin. For now, I like the stock suspension and likely will not change anything there until something wears out.
-ATS TB intake
- Engine lid fan
-K&N FIPK
-TwoRus MBC
-Homemade FCD
-XM radio
-New radiator cap
-Steam clean carpet
-TwoRus shifter kit
