1 - 5 of 5 Posts
My car has a leaking coolant problem and is most likely due to a broken radiator. Where is a good and cheap place to get a raditor for my 96 V6 Camry? Are the eBay ones any good? They sure are cheap(about 80 dollars).
S14 Fever :D
1993 Toyota Scepter
Hmm, first I would check the upper and lower radiator hoses to see if they are cracked and leaking. Because it could just be a hose. Check your Radiator for any cracks too and if it has stress cracks it´s probably leaking.
I´m not sure about the Ebayradiators but I got a new Radiator from Autozone for about $120 and they had it in stock. It worked fine just as good as a oem.
Triple A Whore
Highlander & Civic
Mine is off eBay. It works just like the OEM one. It's been on there for a year and it's been fine.
I also changed the radiators hoses. It wasn't much and I figured that the hoses were as old as the car so why not.
1 - 5 of 5 Posts
