1 - 6 of 6 Posts
BonesandFeathers
94,95 CAmry
We adopted a 20001 Camry CE last week with 127K on the clock..
Most of the problems are minor, and should resolve without too much drama.
The R/F wheel has a minor tremor in it at fwy speed, and so I'm considering a change in rims, as my life would be in peril if i borrowed rims from my wife's SE, So next week or so I'll get the water pump, timing belt, and oil seals so i can lay that to rest.
I am stuck on the radio and humming all the time is getting old.
al suggestions appreciated
Paul in L.A. between downtown Disney and Downtown L.A.
As far as the tire, this car should have a full size spare. Put that tire and rim on the right front to verify the tremor is in the tire/wheel combination and not something in the suspension or the wheel bearing.
Mike
BonesandFeathers
94,95 CAmry
None of the steering or suspension appear to be wiggly , at all. Had the front tires balanced and they were aan ounce and a half and an ounce and3/4s. so rims are cheap at pick-yer-nose
There is no wiggle on ony of the steering or suspension parts, the struts look pretty new and feel OK
The spare tire does not appear to be a virgin So I'm thinking a trip to pick-a-part is in my future.
The A.C. resolved with adding a can and change of 134A, so I have a leak, not surprising, i betting on a 20 year old filter dryer and or hoses.
So now All i need is a radio working
thanks for your time
Paul in L.A. between down town Disney and downtown L.A.
Aftermarket deck for sure, so you can have dem fancy bluetooth hookups to your smartphone.
Or better yet, get a stock cassette model, so you can use one of those 1/8th jacks to cassette adapters :grin:
1 - 6 of 6 Posts
