Hello guys
like I said I'm new to the forums. And looking at a '09 Matrix. Any serious with this year model?
Thx
Thx
Did switching to a heavier oil have any effect on mileage?As a side note, I have performed none of these and my car works fine reasons in red:
- VVT-i sprocket TSB, some owners experienced excessive valvetrain noise coming from the VVT-i system. Most got coverage under warranty. I use synthetic oil 5w30 currently trying 5w40 and this isn't an issue..often from what I have read if it does occur it has no detrimental effect and warranty work to fix it sometimes doesn't.
- recall for adding "Smart Stop" programming, basically cuts throttle if the ECM sees that both the brake and gas are depressed. I have no need for this, I know how to drive, only an idiot presses both of these pedals at the same time.
- also related above - pedal modification, basically shims the gas pedal to make sure that there is no way for it to become trapped under a floor mat I have no need for this, I have the stock floor mats and it is not possible for this to occur. This is for the morons who stack mats and have all kinds of garbage underfoot when they drive.
- recall for power master switch on the driver's door - lack of lubrication or contamination with solvent (ie, cleaning) could result in overheating and damage I don't use solvents for cleaning and my car never gets dirty enough to require more than a damp cloth, it still functions as new with 187K mi on the odo
