Hi there guys and gals!
Im on the verge of taking delivery of a 1990 MR2 series 2. It is a bit of a weird one though! The car was brand new supplied here in Australia as a non Turbo model and in 2001 it had all the turbo goodies added and has been thru the local compliance testing and inspection and it has a blue compliance plate to confirm that the installation was done correctly. Now I'm assuming that it has the CT-26 turbo fitted to the engine and if this is the case I have the following questions.......
1. Does the CT-26 have an external wastegate which can be changed?
2. Do I need to change the wastegate to run higher boost pressures? (I'm aiming for about 16 psi)
3. Is changing the intercooler a nightmare of a job?
4. Is a cone filter better than a panel one and if so which cone filter would be the best investment?
5. Which kind of exhaust system would benefit the mods I'm looking to do to the car (Wastegate, EBC, Intercooler).
Thanks for checking this post out and if you have any help or suggestions I would be really grateful! Top site by the way!
Craig
Craig
