1 - 9 of 9 Posts
T-SB-0094-09 March 19, 2009​
2GR-FE Engine Ticking Noise and / or MIL ON P0014,
P0015, P0024, P0025, P0017, or P0018​
Service
Category​
Engine/Hybrid System
Section​
Engine Mechanical Market USA
Applicability​
YEAR(S) MODEL(S) ADDITIONAL INFORMATION​
2005 – 2009 Avalon
2007 – 2009 Camry VDS(s): BK46K
2008 – 2009 Highlander
2006 – 2009 RAV4 Engine(s): 2GR
VDS(s): BK31V, BK32V, BK33V, BK34V, BK35V,
ZK31V, ZK32V, ZK33V, ZK34V, ZK35V
2007 – 2009 Sienna​
Introduction​
Some 2005 – 2009 model year vehicles with 2GR-FE engines may exhibit a ticking/clicking type
noise from the cylinder head cover area which may be accompanied by a MIL “ON” and one or
more VVT-i related Diagnostic Trouble Codes (DTCs). Please use the following repair procedure to
address customer concerns.​
2GR-FE Engine Ticking Noise and / or MIL ON P0014, P0015, P0024, P0025,
P0017, or P0018​
Warranty Information​
MODEL OP CODE DESCRIPTION DRIVETRAIN
TIME OFP T1 T2​
Avalon 2WD 16
Camry 2WD 14.3
Highlander 2WD 16.6
AWD 17.1
RAV4 2WD 15.4
AWD 16
Sienna 2WD 14.1
EG8053 R & R Exhaust VVT-I Gear,
Camshaft, Camshaft Housing
AWD 14.3
– Combo A Add R & R Intake VVT-I Gear – .2
– Combo B
Add R & R Exhaust VVT-I
Gear, Camshaft & Camshaft
Housing (Opposite Bank)
– 1.2
– Combo C
Add R & R Exhaust & Intake
VVT-I Gear, Camshaft, &
Camshaft Housing (Opposite
Bank)
– 1.4
13080-31030
13080-0P020 91 99​
APPLICABLE WARRANTY​
• This repair is covered under the Toyota Powertrain Warranty. This warranty is in effect for 60
months or 60,000 miles, whichever occurs first, from the vehicle’s in-service date.
• Warranty application is limited to correction of a problem based upon a customer’s specific
complaint.
Parts Information​
QUANTITY
PREVIOUS PART
NUMBER
CURRENT PART
NUMBER PART NAME BANK 1
REPAIR ONLY
BANK 2
REPAIR ONLY
BOTH BANKS
REPAIR​
11103-3102#
11103-0P01# 11103-0P014 Housing Sub-assembly,
Camshaft, RH 1 0 1
13502-31040
13502-0P020 13502-0P021 Camshaft Sub-assembly
No.2 1 0 1
11104-3102#
11104-0P010 11104-0P011 Housing Sub-assembly,
Camshaft, LH 0 1 1
13054-31030
13054-0P020 13054-0P021 Camshaft Sub-assembly
No.4 0 1 1​
P0017, or P0018​
Parts Information (Continued)​
QUANTITY
PREVIOUS PART
NUMBER
CURRENT PART
REPAIR ONLY
BANK 2
REPAIR ONLY
BOTH BANKS
REPAIR​
13080-31030
13080-0P020 13080-0P040
Gear Assembly,
Camshaft Timing,
Exhaust, LH
1 1 2
13050-0P###
13050-31### 13050-0P070 Gear Assembly,
Camshaft Timing 1* 1* 2*
17176-0P020 Same Gasket, Air Surge Tank
to Intake Manifold 3 3 3
17177-0P020 Same Gasket, Intake Manifold
to Head, No.1 1 1 1
17178-0P020 Same Gasket, Intake Manifold
to Head, No.2 1 1 1
11159-0P010 Same Gasket, Camshaft
Bearing Cap Oil Hole 4 4 4
90430-A0001 Same O-ring (standard part) 2 2 2
90430-12031 Same Gasket, Oil Pan Drain
Plug 1 1 1
15147-0P020 Same Gasket, Oil Strainer 1 1 1
12151-0P010 Same Gasket, Oil Pan 2 2 2
96721-19010 Same O-ring, for Oil Level
Gauge Guide, No. 2 1 1 1
90301-12018 Same O-ring, for Oil Level
Gauge Guide 1 1 1
15193-0P010 Same Gasket Oil Pump 1 1 1
11213-0P010 Same Gasket, Cylinder Head
Cover 1 1 1
11214-0P040 Same Gasket, Cylinder Head
Cover No. 2 1 1 1
90430-16016 Same Gasket, Oil Pipe No. 2 2 2 2
90430-16012 90430-16017 Gasket, Oil Pipe No. 1 4 4 4
90311-A0005 Same Seal, Oil, for Timing
Gear Case 1 1 1
11328-0P010 Same Gasket, Timing Gear
Cover 1 1 1
96761-24021 Same O-ring (standard part),
Coolant Pipe 1 1 1
90301-79006 Same O-ring (for Oil Filter Cap) 1 1 1​
P0017, or P0018​
QUANTITY
PREVIOUS PART
NUMBER
CURRENT PART
REPAIR ONLY
BANK 2
REPAIR ONLY
BOTH BANKS
REPAIR​
96723-35028 Same O-ring (for Oil Filter
Cap Drain Plug) 1 1 1
16325-31010 Same Gasket, Water Inlet
Housing No. 2 1 1 1
90080-43036 Same Gasket, Exhaust Pipe 1 1 1
04152-31090 04152-YZZA1 Element Kit, Oil Filter 1 1 1
16271-0P010 Same Gasket, Water Pump 1 1 1​
* Part may not be needed based on inspection.​
Required Tools & Equipment​
REQUIRED MATERIAL PART NUMBER QTY​
Three Bond 1324 or Equivalent – As Needed
FIPG Sealant or Equivalent 08826-00080 As Needed
Toyota Genuine Seal Packing Black, Three Bond 1207B, or
Toyota Genuine Seal Packing Black, Three Bond 1282B, or
Toyota Genuine Adhesive 1344, Three Bond 1344, or Equivalent – As Needed
ILSAC GF-4 Multi-grade SAE 5W-30 00279-1QT5W-01 6.0 U.S. qts.
(5.7 liters)
Super Long Life Coolant (SLLC) 00272-SLLC2 9.5 U.S. qts.
(9.0 liters)
Oil Filter Wrench*​
09228-06500-02 1
Companion Flange Holding Tool*
NOTE: All Components from this kit/set are required.
09330-00021​
1
Universal Puller Set “C”
09950-50013-01​
1
Gasket Seal Cutter*
09032-00100 1
* Essential SST.​
NOTE​
Additional SSTs may be ordered by calling 1-800-933-8335.​
P0017, or P0018​
Required Tools & Equipment (Continued)​
REQUIRED EQUIPMENT SUPPLIER PART NUMBER QTY​
R134-a Refrigerant Recovery/Recycling
Machine ADE Robinair ROB34200*
(or equivalent) 1​
NOTE​
Additional refrigerant service equipment may be ordered by calling Toyota Approved Dealer
Equipment (ADE) at 1-800-368-6787.
Inspection Procedure​
1. Start the engine and listen for any ticking/clicking type noises coming from the VVT-i gear
area of the engine.​
NOTE​
This condition may or may not be accompanied by one or more of the following DTCs stored in
the Engine Control Module (ECM) (SAE term: Powertrain Control Module/PCM).​
A. P0014: Camshaft Position “B” – Timing Advanced or System Performance (Bank 1)
B. P0015: Camshaft Position “B” Timing Over Retarded (Bank 1)
C. P0017: Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)
D. P0018: Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor A)
E. P0024: Camshaft Position “B” – Timing Over-Advanced or System Performance (Bank 2)
F. P0025: Camshaft Position “B” – Timing Over-Retarded (Bank 2)
2. Remove the cylinder head cover and inspect the Exhaust VVT-i Gear Assembly on the affected
cylinder bank.​
NOTE​
If no concerns are found with the VVT-i gear actuator bolts, the actuator center section
alignment or actuator body this TSB does NOT apply. Refer to Repair Manual procedures
for further diagnosis.
Repair Procedure​
1. If any concerns are noted with the exhaust VVT-i gear bolts or actuator follow the four steps
below:
A. Replace the camshaft housing sub-assembly, exhaust camshaft, and exhaust VVT-i gear
assembly on the​
affected bank.
P0017, or P0018​
Repair Procedure (Continued)​
B. Inspect the intake VVT-i gear assembly and bolts on the​
affected bank. Replace the intake
VVT-i gear assembly if necessary.
C. Inspect the
opposite bank exhaust VVT-i gear actuator and bolts. If any concerns are
noted replace the opposite bank camshaft housing sub-assembly, exhaust camshaft, and
exhaust VVT-i gear assembly.
D. Inspect the
opposite bank intake gear actuator assembly and bolts. Replace the intake
For complete disassembly procedures refer to the Technical Information System (TIS), applicable
model and model year Repair Manual:
2005 model year Avalon Repair Manual, Engine/Hybrid System,“Engine Mechanical: Camshaft
(LH Bank) 2GR-FE : Replacement”
Camshaft (RH Bank) 2GR-FE : Replacement”
2007/2008/2009 model year Avalon Repair Manual, Engine/Hybrid System,“2GR-FE Engine
Mechanical: Engine Unit: Disassembly”
2007/2008/2009 model year Camry Repair Manual, Engine/Hybrid System, “2GR-FE Engine
2008/2009 model year Highlander Repair Manual, Engine/Hybrid System, “2GR-FE Engine
2006/2007/2008/2009 model year RAV4 Repair Manual, Engine/Hybrid System, “2GR-FE
Engine Mechanical: Engine Unit: Disassembly”
2007/2008/2009 model year Sienna Repair Manual, Engine/Hybrid System, “2GR-FE Engine
For complete reassembly procedures refer to the TIS, if applicable etc.
2007/2008/2009 model year Avalon Repair Manual, Engine/Hybrid System, “2GR-FE Engine
Mechanical: Engine Unit: Reassembly”
Engine Mechanical: Engine Unit: Reassembly”
2. Start engine and test drive to verify the repair.​
Pretty scary. No MILs here. I'll give it a couple more years.
The tick doesn't bother me. But, the repair above, along with the competence of the dealer technicians, does.
I'll probably ignore it until a MIL pops up.
08 Highlander LMT
Is the ticking noise referring to the noise at start-up that tends to go away as the engine warms to normal operating temperature?
2008 Highlander
MIL what?
The dealer can't change the oil good enough let alone take the engine apart. I wouldn't let them touch my car. Although if they mess it up, you could get a new highlander out of the deal
i am thinking of buying a used sienna but it has this clicking also. Anyone of you have a sienna with the same issue? I'm wondering if I should stay away if this is a real engine damage type of issue.
What is MIL?
I have a new 09 Highlander that ticks and has less than 2000 miles.
I thought it was breaking in. But who knows now.
What does MIL stand for?
MIL = malfunction indicator lamp. Basically the check engine light and the code it represents on the computer.
1 - 9 of 9 Posts
