Except for when the PO changes the motor, head, valve cover, etc like mine. I haven't checked all the numbers, but the valve cover said 22RE when I bought it, definitely not a 22re under there. Oh, and my hood is a after market knock-off, no labels at all.If you open your hood (which you should often to check fluid levels) you will see a label on the valve cover,if there is a round air filter on top of the valve cover then you have a 22R=carburator,you can also see the carb itself. You have a 1993 therefore I am pretty certain you have a 22R-E, for full details since you asked such a basic question I thought I would give you full details about the 4-Runners/pickups:
In North America the 22R & 22R-E s are used in the following:
22R
1981-82 Toyota Corona
1981-83 Celica
1981-87 Toyota pickup (up to 1990 on 2wd)
1984-87 Toyota 4-Runner
22R-E (22REC=California emissions=extra charcoal canister)
1983-85 Celica
1985-95 Toyota pickup
1985-95 Toyota 4-Runner
22RTE (Turbo EFI)
1985-87 Toyota pickup
1985-87 Toyota 4-Runner
22R Series tech data:
http://www.babcox.com/editorial/ar/ar119838.htm
http://www.babcox.com/editorial/ar/ar400108.htm
http://www.toyotaperformance.com/flow22r_re_stock.htm
http://www.toyotaperformance.com/toy_22r_re_mod.htm
http://toyota.off-road.com/toyota/article/articleDetail.jsp?id=274605
http://www.lcengineering.com/TechNotes/TechNote48.htm
http://www.toysport.com/Technical Information/22r_tech_notes.htm
http://www.off-road.com/toyota/tech/other/toy_motor.html
http://www.off-road.com/toyota/tech/other/4_dts.html
http://en.wikipedia.org/wiki/Toyota_R_engine#22R
http://www.4x4wire.com/toyota/faq/parts
http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Engine.html
http://www.toyota-mods.org/engines.txt
http://www.toyotagtturbo.com/engines2.html
http://www.bitwalla.com/cruisers/info/engines.html
http://www.off-road.com/tlc/faq/engine.html
http://www.jnc.farpost.com/toytech.html
http://lcengineering.com/TechNotes.htm
http://www.buschtaxi.net/de/01info/motoren.html
http://www.landcruiser.hu/motorok.html
http://www.toysport.com/Technical Information/Transmissions.htm
http://toyota.off-road.com/toyota/article/articleDetail.jsp?id=274536
http://users.tpg.com.au/users/loats/technical/ma61/gearboxes.html
http://en.wikipedia.org/wiki/Toyota_transmissions
http://www.autoshop101.com/forms/h16.pdf
4-Runner/pickup history:
http://www.showmesome.info/hilux/info/history.htm
http://www.automotiveforums.com/vbulletin/showthread.php?t=359043
http://www.brian894x4.com/Toyotapickup4Runnermodels.html
http://www.off-road.com/toyota/4runner/history.html
http://www.toyoland.com/trucks/4runner.html
http://www.toyotatuners.com/forum/showthread.php?t=79
http://www.toyotatuners.com/forum/archive/index.php?t-79.html
http://www.toyotaoffroad.com/Articles/History/History_4Runner.htm
http://www.toyotaoffroad.com/Articles/History/history_truck.htm
http://en.wikipedia.org/wiki/Toyota_4Runner
http://en.wikipedia.org/wiki/Toyota_Truck
http://en.wikipedia.org/wiki/Toyota_Pickup
http://www.top4runners.com/ja/runhist1.html
http://www.top4runners.com/ja/runhist21990.html
http://www.top4runners.com/ja/runhist31996.html
http://www.top4runners.com/ja/runhist42003.html
http://offroaddirectory.net/1985_toyota_4runner.htm
http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Gearboxes.html
http://www.answers.com/topic/toyota-w-transmission-1
http://forums.bauchan.org/portal/viewdownloads.php?rid=66
VIN & axle decoding sites:
http://www.brian894x4.com/Gearratiosanddiffs.html
http://www.geocities.com/toyotashawn/ratios.html
http://www.sor.com/TranGearRatio.html
http://www.4crawler.com/4x4/4R_TechInfo.shtml#DiffRatios
http://home.4x4wire.com/erik/diffs
http://www.4x4wire.com/toyota/faq/vin
http://www.toyotanation.com/forum/t81102.html
http://www.4crawler.com/4x4/ToyVIN.shtml
http://www.showmesome.info/hilux/info/vin
http://www.vinguard.org/vin.htm
http://en.wikibooks.org/wiki/Vehicle_Identification_Numbers_(VIN_codes)/Toyota/VIN_Codes
http://www.autobaza.pl
http://ourworld.compuserve.com/homepages/stepho/oldcodes.htm
http://www.off-road.com/toyota/tech/other/4_axles.html
http://aarc.epnet.com/application/8578/8578.htm
http://www.autoinsurancetips.com/toyota_vin.htm
http://www.paintscratch.com
http://www.toyotareference.com
Sidney® ™
Repairs TV's,VCR's,home/car audio out of my apartment
E-mail:sidneybek(at)yahoo.com
Dartmouth,Nova Scotia
Canada
