Hey all,
moving from one problem to another with my transmission replacement on my 2007 matrix xr.
Got everything back together and test drove it yesterday. it feels like the clutch is slipping a bit going into first. I feel a loss of power with a small increase in rpm while starting up hill or starting quickly. Car smelled burny after 20 miles and back in the garage. I have heard different things about the clutch needing to be "broken in" but this seems like a issue that is not going to fix its self.
I was careful about not getting grease on the flywheel or clutch (used brake cleaner), am sure i installed the clutch the right direction, the fork and bearing moved well. i had some issue getting the trans to line up but it went together without too much fighting. It may have hung up a little on the clutch but not sure... this is my first attempt at doing a job like this. The only thing I can think is that i unknowingly bent the clutch while the trans shaft while installing.
Basically i'm hoping to have a decent guess as to what i did wrong. That way if i have to take the transmission off again at least i wont make the same mistake again.
Very discouraged, any advice is welcome
Thanks!!
Thanks!!
