1 - 6 of 6 Posts
Trailer Trash Engineer
Unless you're planning major rear end mods to lay down serious traction, and are building a SERIOUS small block, you don't really need the TH400. A TH350 can handle quite a bit and uses less power to operate. In fact, a 700R4 might be cool, then you can have overdrive. What rear end are you going to use anyway? I can't see the Celi rear holding up to that.
Nice. Be like the Toyota version of the V8 Datsun 240Z conversion. Should be pretty fun to play with when you're done.
1 - 6 of 6 Posts
