1 - 9 of 9 Posts
HID/Retrofit Expert
2002 Camry LE
Uh... I use the NGK IX Iridium ones... I only paid about $30 for 4 of them. Great plugs.
HID/Retrofit Expert
2002 Camry LE
You won't feel any gains from new spark plugs unless yours are just incredibly shitty or really really really really worn out. For a Gen 5, you won't feel any difference. The only thing I got was that the car starts easier, especially on cold starts.
VeeZed
1988 Toyota Camry V6
I use Iridium IX aswell, fantastic plugs. You won't gain anthing by using them, apart from less spent time etc in removing your intake plenum and replacing the rears if you have a V6. These last around 100k. If you have an I4, you can use them still, but maybe not worth it, as changing plugs on it is a sinch.
The Greatest
ToyS4me said:
does it help performance wise.
No. Don't believe the "It explodes at higher temps which gives you more power"
That is an absolute myth.
The only thing that high temp plugs do is make it less likely for carbon to build up. Carbon build up is what makes your plugs ineffective over time.
1 - 9 of 9 Posts
