1 - 14 of 14 Posts
· Goes Against The Grain
02 Camry SE V6
This has been covered several times. Do a search there is 2 good threads one thread i made is a DIY (search tail light tint VHT Nite Shade DIY).
The cutting of the film is the easy part, getting it on without bumps, bubbles and creases is the hard part.
I use Nite Shade, very easy to do, and you can go as light or as dark as you want.
Discussion Starter · #7 ·
Did you tape the reverse lights and then spray the nite shades on?
02 Camry SE V6
2010 Camry Le
i tried doing the film and failed :( but im going to try again next time. is it normal to have one side of the film tint sticky and the other side smooth? maybe i bought the wrong one...but yea. i wouldnt go nite shade unless youre positive that you wont go back to normal
Discussion Starter · #11 ·
i think its normal to have one side of the film sticky b/c you have to apply some kind of solution to the film to make the tint stick to the tail light...then you have to squeegee out the solution....i think i might go with the film tint b/c i already have a heat gun and film costs like $10 on ebay
· Will
Camry
well i bought a pre-cut it took a while to install and not perfect but it was ok i also bought a kit from pepboys that come with a spray bottle and a squeegee and i use a hair dryer since i dont have a heat gun :lol: but i have to remove mine last year i got a fix a ticket $25 well gl
02 Camry SE V6
Yes stick side is normal.... soap water in a spray bottle is your best friend... and a hairdryer and squeegee
1 - 14 of 14 Posts
