I have a 93 camry and brake lights don't come on and can't shift out of park unless using the override button. I hear a click and can feel the click in the steering column when I depress the shifter button. I searched the forum and the general consensus regarding this problem is the brake light switch above the pedal. My question is can this be adjusted? I looked at it and it seems as if the pedal never really depresses/releases the switch. Also, can I find the replacement procedure in the Haynes book? If so, i'm heading to the store. Thanks in advance.
