Hi I just bought a 90 4runner v6 4x4 ... it's got 8" lift on 35x12.50x16
The previous owner replaced the master cylinder and I was sure they did not bleed it right because I have no brake pressure! Well I gravity bled front brakes and they are working... I did bleed the lspv ( which is no longer mounted on axle) it is possible there is more air in there but I can't get no fluid to rear wheels at all! I have to press pedal to floor to get any brake pressure for the truck to stop.
Any ideas on what I can do? I did gravity bleed lspv first and fluid was steadily coming out and then a buddy pushed down while I opened and then off when I closed it....
Any help would be great before I run someone over.
oh yea and rear ABS light is on.. rear end has been changed i have no clue if it's the stock one or not
