1 - 8 of 8 Posts
Starter removal
Problem I've got is, I turn the key, I can hear the solenoid drop, but it doesn't crank. At one stage, if I jumped it off another car, it worked (even though the battery was fine).
Are Camry's known for sticky starters? Or should I be looking at the aftermarket immobiliser?
Discussion Starter #2
Forget that, just realised the starter was easier to get to than I thought it was. Hammer test says sticky starter :)
Any good tips on removal?
Thanks for the info. Going to have to try and find a reasonably cheap UK source for the contacts now :S
Nice to see user-servicable components on a part like that.
Going to rainforest, BRB
2014 Tacoma 4x4 RC
timebuilder said:
Just be glad it isn't branded "Lucas."
:lol:
Anything you wanna elaborate on, timebuilder? ;)
Grumpy, but good at it
I don't remember it being hard to remove. Disconnect positive battery cable, disconnect starter cable, remove two bolts holding starter to transmission...should fall out in your hands!
1 - 8 of 8 Posts
