You guys know what might cause this? I've checked all the fuses and relays.....everything is Ok. The dimmer for the guages,shifter,and radio works fine except for the A/C control panel.
Man I've been having alot of electrical problems lately. I'm not good with this kind of stuff. I have so many homemade switches....its ridiculous. Right now I have a direct line from my batt. to the A/C compressor to just turn it on. Now there's something wrong with the lead connecting to the A/C Clutch.
I also have toggle switches for my power windows cuz' the master control switch is all jacked up. I even have a switch to light up the reverse lights manually just so I can pass inspection
I even have the "airbag" warning light on. If it has a blown fuse it turns off....if i put a fresh one in, the light goes On. Weird.
Oh yeah my speedometer and the odometer stop working a couple years ago....mechanics say its the speedo cable
but our camrys are electronically controlled.
Oh well I still love this car
If you guys know how I can fix any of these....I'd appreciate it. Thanks
Rob 92' Camry LE
Rob 92' Camry LE
