Did you bench bleed the master cylinder before putting it in? Also, is it a rebuilt or brand new? I have seen more than one bad rebuilt from Advanced Auto parts. You also didn't mention rear wheel cylinders. Take a look and see if they are leaky.
Well there's your problem. You should have bled all four brakes.davidcl said:. As I said, I bleed all four tires
I like someone with a sense of humor.:bump:knowltondata said:Well there's your problem. You should have bled all four brakes.
