1994 Toyota Pick-up 22RE. 195K miles. (My moms truck)
So the shifter is now stuck in the neutral position. The Clutch just goes all the way to the floor with no resistance. I checked the clutch resovior and it was empty.
It sounds like the steps would be to fill up the clutch resovior with brake fluid and bleed the system first right? Is there a "how to" on bleeding the system? (never done it before)
If that doesn't do the trick it would probably be the Clutch master cylinder? or the Slave? How would you tell which one is going bad?
Thanks! I gotta get mom back on the road.
