Daughter came home for lunch and when she went to leave no start. Turns over but would not start unless u worked the gas pedal. Used my innova Bluetooth scanner and had no codes.
My thoughts where idle air control value or maybe throttle position sensor. So I removed the right side throttle body to make it easier to remove the iacv. Got it apart ant it was very dirty cleaned with b12 relubed the bearing on the valve shaft and reinstalled.
Disconnected the battery and turn the key to the on position to clear the computer. So it could relearn the iacv. Upon starting idle was high at 1800rpm. Drive it for a few miles and now everything is fine.
Hope my problem doesn't come but, however I am glad I didn't waste money throwing parts at it. Posting with hopes it help some one else out. 216k and going strong again.
