1 - 1 of 1 Posts
G
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.2) Gecko/20040804 Netscape/7.2 (ax)
X-Accept-Language: en-us, en
MIME-Version: 1.0
Newsgroups: alt.autos.lexus
Subject: Re: Washer liquid warmer
References: <[email protected]> <[email protected]> <[email protected]> <[email protected]> <[email protected]> <[email protected]>
In-Reply-To: <[email protected]>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
Message-ID: <[email protected]>
Lines: 41
NNTP-Posting-Host: 72.141.102.66
X-Trace: sv3-QI2AGSOVBy4YsnHDhvCJAHwM6tsT2W/IFlfwkNT6csSWR6m+lPCZf/bsWBBlw0qrTR1wtaUmcHVRlev!xYXFLdkB4uBXx0ib+xOgWX3SVvaIfVP/htjVDqnco2ki1zsaQRdu0H6u9lcb6VCn93Qm8Jd+
X-Complaints-To: [email protected]
X-DMCA-Complaints-To: [email protected]
X-Abuse-and-DMCA-Info: Please be sure to forward a copy of ALL headers
X-Abuse-and-DMCA-Info: Otherwise we will be unable to process your complaint properly
X-Postfilter: 1.3.32
Xref: news.astraweb.com alt.autos.lexus:14340
"Huge Goat Schmeisser" <[email protected]> wrote in message
news:[email protected]
>> > The problem is, that -40º fluid sits in the nozzles overnight,
>> > evaporating off the methanol fraction. Minus the alcohol, washer
>>fluid > is just water and detergent.
>> > And guess what water does at -40º? Nozzles can and do freeze up.
>>Huge Goat, if we were to believe that tripe, we wouldn't bother using
>>windshield washers at all, because following your theory, the "fluid
>>sits in the nozzles overnight, evaporating off the methanol
>>fraction"! Nonsense Huge Goat! "the methanol fraction" does not
>>evaporate overnight! Give your head a shake Huge Goat!
> Perhaps you need to give your own head a shake.
> I live in Ontario, Canada. I suppose I'm imaging the frozen nozzles I
> /personally/ experience at least a couple of times every single winter?
> By the way, a quick fix is to place a (warm) thumb over the nozzles for
> a minute (or as long as you can stand). This is often enough to thaw
> the fluid so as to allow the nozzles to function again. Once they start
> working, they're normally fine for the rest of the day, even if the
> temperature stays low.
You pussies up in the Ottawa area do little but moan and whine in the
winter. You must be a politician or an uncivilized servant. You'll go
out and skate on the Rideau, but you don't want a dirty windshield to
get there! Try public transit! Go up to Moose Factory for a winter and
then you'll have something to whine about! "frozen nozzles...at least a
couple of times every single winter"! Whoopie Doopie! A couple times
each winter! Big f***ing deal! Get a grip man! Give your head a shake
Huge Goat! You're an embarrasment to your country!
1 - 1 of 1 Posts
