1 - 5 of 5 Posts
I was gonna hop on here real quick to see if I could find a couple pictures to make my belt changing a little easier. I couldn't find ANY at all !
are there any how tos/DIYs on serpentine belt changing??
I'll be outside in the rain swearing for a while thanks :)
Supafly
1991 toyota pickup
Really isnt anything to discuss.. Loosen adjuster bolts, remove belt, get new belt in (depending on what accessory you're working on you might have to slip it over the fan) get it on the pulleys and tighten.
You'll have to adjust them once or twice in the next while as new belts stretch slightly.
1998 T100 SR5 2WD
I believe there's a locking nut on the front to keep the adjusting bolt from "adjusting" itself. You'll have to loosen those first before doing the adjusting bolt. ;)
There is no serpentine belt on the T100. There are three individual belts for the alternator, power steering and air conditioning. At a minimum you need the alternator belt which also turns the fan and water pump. Keep your old belts for spares for when one breaks on the trail.
1 - 5 of 5 Posts
