So, while troubleshooting a previous issue
http://www.toyotanation.com/forum/6...015/1415210-intermittently-randomly-dies.html
I was checking my fuel pressure regulator (FPR) and discovered that there is no vacuum to it. According to Haynes and Toyota, the pressure should be 40.8 to 41.7, with vacuum. If it is higher, check for vacuum at the FPR. Without vacuum applied to it, pressure will be slightly higher (mine was). Now, the interesting thing is that, where the port is for the vacuum connection to the FPR, you will almost never see vacuum there. Only in extreme cases will you get some due to the venturi effect, caused by very large volumes of air flow through the intake. The few threads that I could find about this note that Toyota is a little loco in the head and the theories usually go that it is hooked up there in case the diaphragm inside the regulator leaks, the excess fuel will go into the intake. Plausible? Perhaps. I really cannot say what was going through the engineer's mind with this design. Some have Tee'd the FPR actually into a vacuum line and blocked off the intake port, to bring the pressure down to specs. Just for grins, I am trying this too. I am curious if my mileage and/or power (with my calibrated butt dyno) will change. Right away, I did notice that the RPM's dropped, immediately, when I hooked up the FPR to vacuum with the engine on. They dropped about 100-200. I would love to hear other theories and thoughts about this. I am most curious.
Stay tuned...
Stay tuned...
