1 - 5 of 5 Posts
Hello!
My Toyota camry 2015 is making a strange noise on the right front I’d say. I have had 3 mechanics checking on it, nobody could find what it is. The wheel bearing and both bolt joint were replaced, and noise continues to go on.
It is not intermittent, and It gets louder in a higher speed.
Have anyone had this problem?
Find a mechanic who has noise locating tool. You clamp the tool on the various parts that you suspect that the noise is coming from. You run the wires from the clamps to the tester, then as you drive you toggle back and forth between the clamps to pin point where the noise is coming from.
Is the noise exactly the same as it was before the repairs were made?
Yes, it’s exactly the same as before.
here is the link of a video that I posted on YouTube with the noise that is making. If you want to check it, please.
Sure sounds like a wheel bearing. Does the noise change if you make hard right or left turns?
2014 Camry SE 2.5
This sounds like a loosen part which goes swinging by the wind beneath the car. Some plastic shield or heatshield somewhere closer to the middle of the car. Have tou checked the car's bottom for loosen components?
1 - 5 of 5 Posts
