Mouse in heater
Mouse in heater. This has happened twice now. The first time it really stunk the next day.
Might need to remove the glove box, but maybe not. Probably would be easier.
Glove box has 3 screws across the top, 1 on the bottom left and a bolt bottom right.
To get to the bolt you have to push the plastic kick panel trim aside.
Remove horiz panel under glove box. It just pulls out.
Remove 3 screws on the bottom of the squirrel cage and pull down.
10mm socket or a torx driver works best
The screw in the back would not go back in, might have had a clip so did not replace, runs fine.
Squirrel cage and motor come out together. Burn mouse in effigy.
Make sure motor plug goes in before reinstalling. Will not reach after it is installed.
Dr. bronners peppermint oil soap diluted and sprayed in the heat ducts, air cleaner box, glove box, trunk and interior floors, helps deter the bloody rodents.
