1 - 10 of 10 Posts
Hey guys, I just installed the new 1.5 inch lift from Northwoods Performance on my 2018 Rav. Although I haven't had it long I would like to share my experiences with you and post updates in the future to let you know how it's performing.
I've been looking at kits since I purchased my Rav. Someone on another forum mentioned Northwoods Performance. I like this kit because it's more then just a lift. It's a performance upgrade over the OEM springs. I also like that it's not just strut and subframe spacers. After a lot of thought, I decided I didn't like the idea of putting spacers between the rear subframe and body. This is because your only lifting the body of the vehicle on the rear and the clearance between the differential and ground stay the same.
Before I installed the kit I decided to take some measurements to see how it would effect the suspension. I took height measurements from the front and rear bumper trim as well as checked the wheel alignment.
The install was pretty straight forward. The kit has easy to follow instructions with color photos. The instructions say it takes 2-3 hours to install the front and 3-4 hours to install the rear. But if your experienced and have the right tools, you can install the whole kit in 3-4 hours.
The rear is lifted by a slightly taller and higher load rated spring. The hardest part of installing the rear was getting the control arm lined up to install the bolt. Using a small pry bar and a large center punch you can get the holes aligned enough to gently tap the bolt in place. I also reinstalled the end link bushing and nut to help keep the arm in place after lifting it with a jack stand.
The front is lifted by a strut spacer and higher load rated spring. Using a wall mounted spring compressor the new springs went on easy. I installed the strut spacers and mounted the assemblies in the vehicle. I had minor issue with the supplied nuts for mounting the strut to the vehicle. The thread pitch was wrong and didn't screw onto the studs. It wasn't a big deal though, I just used the OEM nuts. I reported this to the company and they are working to resolve the matter for future customers.
Installing the sway bar endlinks back on the struts is a bit tricky. With the struts now sitting lower in the vehicle the endlinks were just a little higher then the mounting point. You must have both endlinks disconnected, and I had to temporarily loosen the nuts on the sway bar side to get extra wiggle room so they fit. I noticed the sway bar contacts the lower control arms when the suspension is unloaded. With the vehicle on the ground they raise up off the control arms. This shouldn't be an issue, but I contacted the company to suggest making a bracket to mount the endlink a little higher on the strut. I know there are some other lifts on the market that include a link bracket to prevent this.
Something I did that the instructions don't mention, is putting a little lock tight on the nuts that hold the spacer to the strut. I also torqued the rear lower control arm with the vehicle on the ground. Doing this will prevent premature failure of the control arm bushing.
After the install I rechecked the height measurements and alignment. 1.5" higher in the front and 1.25" higher in the rear. The alignment did need a toe adjustment. Camber is still within specs. Caster was a hair out of spec on the left front, but that usually happens with most lift kits.
So far its been a good kit. The Rav still feels stable on the road and the vehicle tracks straight. I look forward to seeing what else they bring to the market. On their site it looks like they have a skid plate and exhaust pipe in the works.
Discussion Starter #2
One week update:
I haven't been able to hit the trails yet, we just got 1 1/2 feet of snow in the valley a few days ago so the trails are covered in really deep snow. No problems with the lift so far. My wife did mention that the steel wheels look dorky with the lift. I'm not gonna complain though. That just gives me a good reason to spend some tax money on a set of new wheels.
I've been talking with the president of the company. He read my review, and listened to my suggestion on the sway bar link bracket. He told me they fabricated a bracket and are in the process of testing it on their vehicle. When they feel it is ready they are going to send me a prototype for testing as well. Stay tuned!
Driving Update:
I was able to get off the pavement this weekend and try out the lift on some rougher dirt roads. It did really well and the springs really help absorb the roughness. The extra clearance also helped in the dips and holes in the road.
Brackets are on! I'm glad they made these. When I was loosening the nut for the link, the strut moved downward a bit. There was a lot of pressure being put on the links. This bracket relieves that pressure and keeps the sway bar from rubbing on the control arms. No noticable performance gains or loss. Still drives just as good as it has been.
Corolla, Camry, Tundra, Camry, Avalon, Highlander, Venza, Highlander
Hmm now I'm debating on what kit to get. I just ordered the spacer kit but if I remember from lifting my Tacoma I went with a spring kits bc I heard space kits can ride rough. This kit is the same price as the spacers. I want it more for clearance and to get meatier tires on there as well as to help with load from my pop up camper. For the camper issue I would think springs would be better then spacers no? I have the 2018 adventure model btw.
Great post - thanks for sharing! ?
What's been the overall drop in MPG would you say (with lift plus new heavier tires vs. stock)?
Did installing the lift kit affect the SPORT driving mode at all (which seems to stiffen the chassis a bit on my 2017 Hybrid SE)?
Thanks
1 - 10 of 10 Posts
