1 - 6 of 6 Posts
My 2002 Toyota Camry LE V6 is not moving forward when shifting the gear to Drive neither to Reverse. Do you think what would be the issue? I hope not the transmission.
I am also thinking the Gear Oil. If so, what is the recommended or the right Gear Oil?
Need help please. Thanks
it could be low on fluid. it takes type lv my 02 does that on drive sometimes. i have to hold brake and hold engine revs to 3000 for a few seconds than it catches. only way to fix is to replace the transmission
Discussion Starter · #4 ·
When you say revs 3000, is that you hold the brake and then stepped in the accelerator or revolution it? Sorry just trying to do something here. Thank you
1 - 6 of 6 Posts
