hi everyone,
I'm throwing this post up while i search in case someones got an answer off the top of their head. Here's my situation:
89 v6 4x4 186k miles, not sure what if anythings been replaced.
Clutch started making a funky noise the begining of the summer, (throw out bearing? is what everyone said). wasn't shifting too hot so ive just been waitin for it to go basically. The other night i go to back out of a parking spot and the pedal just hits the floor. i was convieniently crooked in a handicap spot:headbang:. I couldnt get it in gear so i shut it down, put it in reverse, started it and parked it out back.
Now its stuck in reverse even with the car off. I've had a clutch go on me before and i could change gears when its off. I took a look at that shifter bushing, doesnt look bad, in one piece that is. So I'm trying to figure out is my tranny messed up too?
I'm gunna take it off to do the clutch... should i be factoring in a rebuild? is something just jammed? any thoughts would be helpful.
An aside, the reason the pedal hit the floor, the rod from the slave cylinder had popped off the fork and was spitting fluid on the ground, i put it back in bled it and now it moves but the clutch is still shot.
