1 - 5 of 5 Posts
1990 Cressida
how's it going. I changed my distributor, rotor and plug wires yesterday and while doing so i noticed what appears to be motor oil around the rim of the distributor cap, and I noticed oil in inside the rim of where the distributor caps attaches. Any idea where this can be coming from?
'90 Cressida
the dizzy has a couple oil seals on it since it gears right to the exhaust camshaft inside the head. if you pull the dizzy out you'll see theres an o-ring on the shaft of the dizzy. it could be as simple as replacing that, a pretty quick job. i'll take some pics of a spare dizzy when i get home from work for you.
Cressida nut
91 Pickup (Hilux)2wd
if it's the external seal that you mentioned it'll just run down the block onto the exhaust manifold. if it's in the cap and around the edges, it's leaking through the internal seal which is a non-serviceable part unfortunately.
Cressida nut
yea ask me how I know about that internal seal :( I got a new dizzy from a partout supposedly with no leak
1 - 5 of 5 Posts
