Nut size???
1261 1
Can anyone tell me the size of the nut that holds the rear hub in place?
This weekend I had to tighten the nut and I used a 1-1/4 in socket which was not the correct size. I was told by coworkers that I should not have used an impact wrench because It will damage the wheel bearings. Tonight I will back the nut out and hand tighten with torque wrench but I would like to purchase the correct socket.
My guess would be a 30 mm socket.
Robinson
Wht 93
Stock
1 - 2 of 2 Posts
You guess correctly. As long as it's the factory axle and nut. (Some aftermarket axles use a different nut size.)
If so, a 1 3/16" socket is much closer. Also, since the torque on that nut is spec'ed at something like 250 ft-lbs, you aren't likely to get it all with your torque wrench. Unless I'm using my impact wrench set at 400 ft-lbs. max, and my (new) 30mm socket, I simply stand on the end of my 18" breaker bar. That puts over 200 ft-lbs. on it.
1 - 2 of 2 Posts
