1 - 20 of 20 Posts
MR2 V6
1991 MR2 Turbo/240sx
I am about to buy a 93 camry v6 manual. thing is when its running it sometimes flashes "O/D off" on the right of the dash. I thought Over Drive was for automatics only. How can I check to see if the car is an original manual car and not a tranny swap?
'96 Camry XLE
Yes, RIGHT down the center between the Tac and Speedo.
Also, the one your looking t MUST be an SE V6, as those were the ONLY V6 92-96 sold with a manual tranny in the us.
'96 Camry XLE
PsychoSquirrel said:
then why the **** is the O/D light flashing on and off?
Cause your special, :lol: . Honestly makes NO sense at ALL. there should not even be an O/D light on a Manual tranny Camry.
Camry
Did Gen 3 SE V6 have automatic transmission as an option?
It could be a swap though. Look for other indications that it's a SE. The back should have a black plate that says Camry rather than the red reflector thing all the way across (though it could be painted). Black mirrors and black side molding should also be present.
5S-FU
96 Toyota Camry LE
The wires for the overdrive can short out sometimes
It happened in my automatic, but you should look into it because if your tranny is switching to o/d spastically, it might screw with it.
Do manuals even have overdrive?
Camry
Manuals have overdrive, depending on the gear ratios. My 07 Camry, technically, has two of them even since 4th and 5th are less than 1:1. But there is no indicator on the dash to say OD Off since that is just telling you the transmission won't shift into OD. On a manual, the driver does the shifting so it's up to the driver when or whether or not to use 5th gear (OD) and the driver can tell which gear the car is in by the way the shifter sits.
'96 Camry XLE
^ See if you can get a pic of it the next time.
Yes they did. I found that out a few weeks ago, :lol:.
TN Pussy Man
Camry
^ lol...a little behind in the times, eh, adam? ;)
but yes, there are plenty more auto SE's out there than 5speeds even...at least here in Canada.
And correction on your previous post as well....5speed v6's only for 92-93 SE's with 3vzfe
and there isn't even an o/d function on a 5spd...no idea why it would be flashing....should try looking at the shop manual and looking at the troubleshooting section
'96 Camry XLE
Here in Connecticut, almost all of the SE 3VZ's are Manual's, haha. Not many Auto's at all.
Gen 3 Camry
good pick up, touringcamry. had the mileage been unusually low i would be suspicious of the real mileage on the car.
however, since it has 203k miles on it, i doesn't really make a lot of sense.
it's sounding more like a transmission swap. the o/d wires run from the little button on the shifter down through the center console. if they're shorting out, i dare say the short would be in the center console area where the old shifter used to be rather than the dashboard.
1 - 20 of 20 Posts
