1 - 6 of 6 Posts
where is the Bank 1, Sensor 1 located on a 2003 toyota tacoma 4wd v6? How many sensors are there? Got the P0031 code. Any help is appreciated.
2002 Tacoma 4x4
Here are some links that should get you on your way. I would go with OEM Denso sensor by the way, aparently they cause the least amout of trouble.
http://www.tacomaworld.com/forum/1st-gen-tacomas/19548-replacing-o2-sensor.html
http://www.lieblweb.com/tacoma/Mechanical/O2Replacement/02Replacement.html
Im sure you could find much on this web site as well, but these are just some quick links i had from when i did mine. Really watch out for those nuts though it could be rough. When I did mine the nuts where literally rusted away to nothing, just enough to make it a pain in the ass to come off, also the nuts are a very uncommon tread can be hard to find. Good luck.
Thanks for the links, I'll try this information out to clear my check engine light with the same code too.
Update: Hey guys, I changed out the front o2 sensor and the check engine is gone. Thanks for the tips, it surely guided me down the right path.
The job was pretty simple. :thumbup:
1 - 6 of 6 Posts
