1 - 8 of 8 Posts
06 4x2 PreRunner DBL
I need an OBD2 Scanner for my three vehicles (10' Tundra, 06' Tacoma, 09' Corolla). Needs to be more than just a reader. I want to be able to do most of the repairs myself. Needs to be able to read and clear Generic and Manufacturer Specific DTC codes; provide DTC descriptions and solutions (no additional charges or fees), ABS/SRS/TPMS are all highly desired but not necessary. Live data is not a necessity - I think.
Anyone have any luck with these:
Autel AL519 https://www.amazon.com/dp/B007XE5LTG...UTZ2TLVO&psc=1
Autel AL619 https://www.amazon.com/dp/B0091DJWV0...D99ZJRNF&psc=1
Innova 3040c https://www.amazon.com/dp/B00W85NZU2...W3XQXH5V&psc=1
Blue Driver https://www.amazon.com/dp/B00652G4TS...I1M72S9BUSNNHZ
Or any other recommendations. Appreciate any feedback.
Administrator
05 Tacoma 4x4 DC LB
05 camry 07 tacoma
Live data is needed to help pinpoint problems. Most inexpensive scanners do code reading/live data scanner. Pay more for ABS/SRS capabilities.
Record/playback option is very useful.
Actron has/had sale on there auto scanner plus with features you described. Last years model around $200.00.
Really if your serious about diagnosis spend a few bucks to take online course such as ScannerDanner.
Its knowing obd2 theory that makes the scanner valuable.
Wasn't to sure why I would need live data, but you've made that a no-brain-er. Any more info about ScannerDanner? Sounds interesting. Gotta look u Actron to see what they have close to my budget. Thanks!
Discussion Starter #6
So, still no closer in making a decision since I originally posted. But after reading other blogs, I now have added another option. Basically a cheap clone TIS Cable and software for Toyota. Claims to be able to do what I want to do and more - except the more advanced stuff that requires a license key form Toyota to access.
Super Moderator
2005 Corolla CE
Techstream would be nice but way outside my budget. I'm hovering around the $100 mark, if not less. Thanks for the suggestion though,
Techstream is available from several sources for WELL within your budget.
Is Autel AL619 still good to use? I have been using Autel Scanner MD802 Maxidiag and its diagnostics is really good and detailed, it has ABS, SRS, EPB and live data. Is Autel AL619 much better?
1 - 8 of 8 Posts
